Config Archive failing for device
Sep 28th, 2009
I am trying to archive all our configs but one keeps failing. I get the following:
Device: SSF2-SA Status: Failed
*** Device Details for SSF2-SA ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> SSH,Telnet
Execution Result:
Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings
I am posting the dcmaservicelog since someone else had a similar issue and was asked to post it.
I am on LMS 3.1 on Windows server 2003.
Joe Clarke Mon, 09/28/2009 - 13:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like you're being affected by CSCsv95235. There is a patch for this bug from TAC, but the recommended fix is to upgrade to LMS 3.2.
