DFM database configuration mode
j.baez
Hi everybody,
I have a problem with DFM database. Everytime i want to run a backup configuration an error comes out:
"Fatal error: Database engine 'dfmEpmEng' could not be started on database 'dfmEpmDb' in Bulk mode.." , then i know i have to change that bulk mode but i can't find out how to.
Can anybody help me fix this issue??
Cheers,
9 Replies 9
Joe Clarke
This looks as though the dfmEpm database is corrupt. Post the output of the pdshow command.
attached is the pdshow results. Hope it's useful.
cheers,
Your service startup parameters have been changed, and this breaks LMS. Post a screenshot of your Services control panel showing all of the CiscoWorks services.
here you are with the Local services Screenshot.
Set the following services to Manual start, then reboot, and see if the problem still occurs:
CiscoWorks web Server
CiscoWorks ANI database engine
CWCS Cmf database engine
DFM dfmEpm database engine
DFM dfmInv database engine
DFM dfmFh database engine
IPM NG database engine
CWAWFEngine database engine
CiscoWorks RME NG database engine
CiscoWorks Tomcat Servlet Engine
Hi j,
I did what you suggested but it didn't work. Still getting the error described at the begining but also some other errors after the server was rebooted. Here are posted the screens with those errors.
Looking forward your answer,
Post the new pdshow output.
this an error i got while trying to run a backup after the changes to the services
this is the way Services are configured
