error PWRCYCLE: Card in module 7, is being power cycled off
Sep 28th, 2009
I have Cisco IDM version 6.1(2)E3.This IDM is module type which once with core switch.The problem its when each time want access GUI use https://10.x.x.x out error 443 and I forced reset ips use command line. When I show log at core switch found PWRCYCLE: Card in module 7, is being power cycled off (Module note responding to Keep Alive polling).
Any body help me...
shairolbit Mon, 09/28/2009 - 23:33
Do caused received packet too high cause CPU high utilization, because guided performance (inline) support up to 500,000 concurrent connection whereas receive packet 10,262,215,327
rhermes Wed, 09/30/2009 - 08:31
The PWRCYCLE log entry in your switch is expected when you reset you sensor. A sensor reset will reload the sensor taking it off the power bus and putting it back on. This results in several switch log messages about the sensor on slot 7.
Your GUI access problem is a different matter. Search this forum for the symptoms you are experiencing. There have been many working solutions to GUI problems posted here.
