Cannot load ASDM after upgrade
Answered Question
Sep 28th, 2009
Not sure where I slipped up, but when I try to load ASDM I get an unable to load ASDM from <ip address> message.
wbdcfw# sh ver
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
wbdcfw up 3 mins 2 secs
Hardware: ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Correct Answer by platinum_jem about 7 years 9 months ago
Make sure you have the following in ur config
http server enable
asdm image disk0://xxx
Overall Rating: 5 (1 ratings)
Correct Answer
platinum_jem Mon, 09/28/2009 - 21:28
http server enable
godinerik Tue, 09/29/2009 - 01:14
You must also specify which addresses are allowed to access it:
http xx.xx.xx.xx netmask [interface] i.e:
http 192.168.100.0 255.255.255.0 inside
or
http 0 0 outside for all of the outside IPs. If all of that is done, clear your browser's cache/cookies, close all browser windows and re-open.
