Unable to connect via Cisco VPN Client
Answered Question
Sep 28th, 2009
I have configured Remote Access VPN on ASA and am trying to connect via the Cisco VPN Client 5.0
I am not able to connect and the log on the ASA shows
ASA-3-713902: Group = xxxxx, IP = x.x.x.x, Removing peer from peer table filed, no match!
ASA-4-713903: Group = xxxxx, IP x.x.x.x, Error: Unable to rmeove PeerTblEntry
ASA does not support K9 i.e. VPN-DES is enabled and VPN-3DES-AES is disabled.
What could be the reason.
Correct Answer by bastien.migette about 7 years 6 months ago
Hi there, I had this same problem, here the solution:
when you do a debug crypto isakmp 255, then you see that cisco vpn client doesn't handle SHA + DES, you have to use MD5 + DES, or sha with 3DES/AES.
Be careful, this debug is very verbose, but that's the only way i found to get SA Proposal on debug.
Well, modify your isakmp policy using MD5/DES would do the trick.
Overall Rating: 5 (1 ratings)
Yudong Wu Mon, 09/28/2009 - 22:41
  • Gold, 750 points or more
Please post your config and the following debug output.
"debug crypto isa"
"debug crypto ipsec"
tech_trac Thu, 10/01/2009 - 04:55
interface GigabitEthernet0/0
nameif OUTSIDE-INTERFACE
security-level 0
ip address 2.2.2.130 255.255.255.224 standby 2.2.2.131
no pim
interface GigabitEthernet0/1
nameif INSIDE-INTERFACE
security-level 100
ip address 10.4.4.1 255.255.255.0 standby 10.4.4.2
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association life time seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association life time kilobytes 4608000
crypto map OUTSIDE-INTERFACE_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO _MAP
crypto map OUTSIDE-INTERFACE_map interface OUTSIDE-INTERFACE
crypto isakmp enable OUTSIDE-INTERFACE
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 2
lifetime 86400
tunnel-group Cisco type remote-access
tunnel-group Cisco general-attributes
address-pool ClientPool
default-group-policy GroupPolicy1
tunnel-group Cisco ipsec-attributes
pre-shared-key *
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
vpn-tunnel-protocol IPSec
address-pools value ClientPool
ip local pool ClientPool 10.4.4.155-10.4.4.165 mask 255.255.255.0
debug crypto ipsec did not give any output.
Output for 'debug crypto isakmp' is below
Oct 01 16:52:10 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Removing peer from peer table failed, no match!
Oct 01 16:52:10 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Error: Unable to remove PeerTblEntry
Oct 01 16:52:15 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Removing peer from peer table failed, no match!
Oct 01 16:52:15 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Error: Unable to remove PeerTblEntry
Oct 01 16:52:20 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Removing peer from peer table failed, no match!
Oct 01 16:52:20 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Error: Unable to remove PeerTblEntry
Oct 01 16:52:25 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Removing peer from peer table failed, no match!
Oct 01 16:52:25 [IKEv1]: Group = Cisco, IP = 81.23.110.120, Error: Unable to remove PeerTblEntry
Yudong Wu Thu, 10/01/2009 - 21:55
So, the above was the only output of "debug crypto isa" when the client initiated VPN connection?
From the config, the only thing which might cause the issue would be the address pool. VPN client's IP address pool is in the same subnet as the inside interface. Could you try to use a different one?
tech_trac Mon, 10/19/2009 - 23:10
But I have configured another ASA with Remote Access VPN with same address pool as inside interface and it
works fine. Which other address pool should I use. Should it be from the subnet of one of the interfaces
or anything else.
tech_trac Tue, 10/20/2009 - 00:26
I changed some configuration and now I am getting "All IPSec SA proposals found unacceptable!" and "Reason: Phase 2 Mismatch" and "Received encrypted packet with no matching SA, dropping"
ASA has K8 license only and 3DES is not supported.
Following is the crypto configs
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map outside_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-DES-MD5
crypto dynamic-map outside_dyn_map 40 set security-association lifetime seconds 28800
crypto dynamic-map outside_dyn_map 40 set security-association lifetime kilobytes 4608000
Correct Answer
bastien.migette Tue, 10/20/2009 - 07:27
Yudong Wu Tue, 10/20/2009 - 08:05
if it says "phase 2 mismatch", you need to change your transform set configuration, Bastien pointed to the right direction.
