VRF Communication
Sep 28th, 2009
Suppose i have 4 vlans (1 server vlan a nd 3 user vlan) in my access switch and in L3(6509) i have made them part of same vrf.Now with all 4 vlans in same vrf can i restrict communication between user vlan==user vlan and allow server vlan==client vlan.
or else only the option is all 4 vlans in 4 diffrent vrfs and only server vlan imorting all user vlan RT's and user vlan only import server vlan RT.
Jon Marshall Tue, 09/29/2009 - 00:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sameer
If they are in the same VRF then can you not just use standard L3 acl's on the vlan interfaces to control the flow of traffic ?
Jon
sameermunj Tue, 09/29/2009 - 00:39
i was just getting the confirmation on weather within same vrf i can control the traffic among diffrent networks using some kind of ACl not the standard ACL on vlan interface?
If i need to use standard ACL only then i think i can bypass the vrf part and can use standard acl on vlan interface in 6509 ???
