Using Video Advantage reboots 2821 ISR!!
Hi everyone,
I have a site that suffers from intermittent router reboots when users within the site use the VTAdvantage cameras for video calls. By disabling all VTA's, everythings fine but even with one VTA connected this can cause the router to reboot. I've had all the hardware (inc DSP's etc) replaced, but this hasnt made any difference. The amount of bandwidth specified for video with CCM (ver 4.1.3) has been set to 2Mbps, each video session takes approx 256k - 312k. Theres nothing in the router logs to suggest any problems - maybe it reboots before it has time to write anything?
I have other sites with the same setup/config etc and these are all fine - it's just this one site.
Any suggestions appreciated!!
Mark.
paolo bevilacqua Tue, 09/29/2009 - 02:33
  • Hall of Fame,
    Founding Member
Which exact IOS are you using ?
