internet router CRASHING - 2801
jvalin__s
hi guys,
we have a problem with the router 2801,
a normal configuration of the pppoe adsl,
ter term length 0
Router#sh run
Building configuration...
Current configuration : 1865 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/3
no aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
username admin password 0 Admin456
archive
log config
hidekeys
interface GigabitEthernet0/0
description *****Connected to Internet *****
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
ip address 192.168.10.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp pap sent-username xxxx password xxxx
ppp ipcp dns request
ppp ipcp wins request
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.11.0 255.255.255.0 192.168.10.1
ip route 192.168.12.0 255.255.255.0 192.168.10.1
ip route 192.168.13.0 255.255.255.0 192.168.10.1
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
control-plane
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router#sh flash
-#- --length-- -----date/time------ path
1 44446708 Jun 22 2009 04:38:52 +00:00 c2800nm-spservicesk9-mz.124-15.T9.bin
2 2751 Jun 22 2009 04:48:28 +00:00 sdmconfig-28xx.cfg
3 931840 Jun 22 2009 04:48:42 +00:00 es.tar
4 1505280 Jun 22 2009 04:48:58 +00:00 common.tar
5 1038 Jun 22 2009 04:49:12 +00:00 home.shtml
6 112640 Jun 22 2009 04:49:26 +00:00 home.tar
7 1697952 Jun 22 2009 0
what is happening is whenever the internet is accessed from the 11,12,13 as well as 10.0 vlan the router is crashing..
Kindly please help
14 Replies 14
paolo bevilacqua
Which exact ios are you using ?
c2801-ipbasek9-mz.124-25b.bin
Try a different release eg 12.4(3h).
Otherwise you've to go to the TAC for the bug to be identified and fixed, can take 6-8 weeks.
yes I have opened a tac case
they have asked..
certain outputs..
what errors I am getting is
"IP NAT AGER" whenever the users access the internt at that time only we get error related to nat memory errors..
and the router gets reloaded.
there might be not enough to hold the nat translations. thats what i think.
As above, you can spend a lot of time doing "show me this and show me that" with the TAC, or switch to an image without the bug and have it working.
Too bad I cannot tell you neither the bug ID neither which version does not have it.
well,
the actual problem what we found was in the lan itself.
We found one PC which was generating lot of traffic to the internet and because of that the processor memory utilization was more.
Thanks for your help. We tested 3 different IOS on 3 different routers actually.
This should fix your problem c2801-ipbasek9-mz.124-25b.bin
Thank you for letting us know.
Routers are not supposed to crash just because a PC sends a lot of traffic, so I still think it is a bug.
but after switching off that pc.
the crashing stopped.
and it was happening on all routers.
2801,2811,2821.
What exactly type of traffic was generated by this host?
well there was nobody surfing from that machine.
What we can see on the router is IP NAT AGER and processor memory utilization errors.
so from this we can conclude that may be something from the host is going to internet. virus?? I am not sure.
A thorough scan is remaining.
For Your own knowledge I suggest to build a simple lab, connect this suspicious host and try to monitor the traffic with for example Wireshark. If this situation repeat You should see in Wireshark what the traffic was transfered during occurance of the router crash.
well even the tac case guys are saying that it could be a worm or virus issue because of which the processor utilization is goin high.
and immediately after removing that host the network became perfectly ok.
sschulak
Can you post
"show stacks"
"show mem stat his"
just post the last graph in show mem stat his.
Also enable ip route-cache flow on GigabitEthernet0/1
and post a "show ip cache flow | i Null" prior to crash.
also "show ip cache flow" during the cpu spike
Also post "show proc cpu | e 0.00 prior to crash.
thanks
