erdalorsavas Tue, 09/29/2009 - 02:00
please forgive my stupidity,
could you please give me a configuration example about it ?
erdalorsavas Tue, 09/29/2009 - 03:07
thanks for your fast reply,
when I try to do put fastethernet to bridge-group it says the following message:
HSM(config-if)#bridge-group 1
FastEthernet0 does not support bridging
is it a fixible issue ?
thank you so much.
erdalorsavas Tue, 09/29/2009 - 04:02
hi again,
sorry being headacke to you.
now my vlan1 is up bu I couldn't up my atm interface. it says down all the time.
do you have any idea why is that for ?
thanks a lot
erdalorsavas Tue, 09/29/2009 - 07:27
hi,
thank you for all your advices. it has been very helpful to me. I solved my problem. thank you again.
