LMS 3.1: managing devices in CM and RME
Sep 29th, 2009
I've some devices that are managed by RME, but not by CM. Some others are managed by RME and CM, but the device type is not discovered.
Please help me to find and fix the cause for this.
Thanks in advance.
Joe Clarke Tue, 09/29/2009 - 06:56
What types of devices are these? what are their sysObjectIDs? Exactly what version of Campus Manager do you have?
mwynen Tue, 09/29/2009 - 21:16
Devices that are managed by RME and CM but don't show device type: WS-C3508G-XL, WS-C3550-48 and WS-C3560-48PS.
Devices that weren't managed by CM but by RME can't be found any more. Could this belong to importing them by a file using bulk import (CLI command executed by a script)?
We're using Campus Manager 5.1.0
Joe Clarke Tue, 09/29/2009 - 22:04
What do you mean "don't show device type"? You didn't post the sysObjectIDs, but it looks like all of these devices should be supported out-of-the-box by LMS 3.1.
mwynen Tue, 09/29/2009 - 23:32
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::catalyst3508GXL
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::catalyst355048
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::catalyst356048PS
What I meant is, Device Center shows Device Type as UNKNOWN.
Joe Clarke Wed, 09/30/2009 - 06:59
Post the NMSROOT/lib/classpath/com/cisco/nm/cwcs/mdf/mdfdata.xml file.
Joe Clarke Wed, 09/30/2009 - 21:18
Your MDF version checks out. All of these switch types are supported. If they are showing up as unknown in the device selectors, then the LMS applications are not able to communicate with these switches via SNMP. Verify that the SNMP credentials are correct in DCR, then try performing an RME inventory collection for them. If that job fails, post the IC_Server.log.
mwynen Wed, 09/30/2009 - 22:11
Device credentials are all correct (Check Device Credentials is successful) and the inventory can successfully be collected.
Joe Clarke Thu, 10/01/2009 - 08:15
Try removing one of the devices from DCR, then re-add it. Make sure RME properly manages the device, then post the IC_Server.log and EssentialsDM*.log.
