7925 connection failed with Extension Mobility
testeven Tue, 09/29/2009 - 06:09
Hi!
Can you please check that you are using the latest firmware on the 7925?
What error do you get on the screen? Something like "xml 4 parse error"? If you do, please check CSCsy60203.
Teresa.
shikamarunara Tue, 03/22/2011 - 12:38
Were you able to find a solution to this problem?  I am experiencing the same issue myself.
