Share point portal access using ssl webvpn
Sep 29th, 2009
i am trying to have sharepoint folder being made accessible via ssl webvpn. I did put in web acl with its ip and some known ports,but it doesnt work. Is that since the share point is usually like //abcd/path1, i cant filter by ip rules.
Please advise.
platinum_jem Tue, 09/29/2009 - 23:45
It should work fine.
Can you give more information?
1) Whats is the configuration you use, the equipment you are using ?
2) What do you mean by 'doesn't work' ? What happens when you click on the link ?
suthomas1 Sat, 10/03/2009 - 23:46
this is being setup on a ASA 5520 ver 8.0
i have enabled rules to the sharepoint with netbios-ssn service, but it gives "cant find server or dns error" while accessing.
I only see UB flags being set when the conn is initiated from vpn segment.
