Shutdown Unused Ports
Sep 29th, 2009
I'm using the TCL scripts that Joe Clarke produced in the conversation on shutting down unused ports from Aug 25. It appears like the script is running, and it even produces the susp_ports.dat file, but none of the ports are shut down. I tried it by setting the suspend_ports_days variable to 2 days, but after 4 days no ports have been shut down. Any suggestions?
Giuseppe Larosa Tue, 09/29/2009 - 06:25
  • Hall of Fame,
    Founding Member
Hello Brian,
I think you should post this under network management where it is more likely that Joe and others can read it.
ignore my note if you have already done this.
Hope to help
Giuseppe
