Re: Cisco Unified Presence 7.0 Installation
Sep 29th, 2009
I have a MCS-7816-I3-IPC server that I am going to load on Cisco CUP 7.0 Application Software on. Which server O/S should I load on the server first (2003/2008), should I be setting up partitions prior to the OS install? If yes what is the reccommendation? Do I need to load on Server OS prior to loading the Cisco Unified presence software?
Overall Rating: 5 (1 ratings)
Jaime Valencia Tue, 09/29/2009 - 07:32
CUPS 7 is a Linux appliance, the DVD installs the OS and CUPS at the same time
Please refer to CUPS install guides
java
if this helps, please rate
