Unity 5x integration with Exchange Server
Answered Question
Sep 29th, 2009
I have a stand-alone unity 5x with onboard Message Store integrated with CUCM7.x. Client wishes to now integrate with their exisiting Exchange 2003 environment for voicemail in their email inbox. I am having a difficult time finding the correct documentation/procedure for doing this (integrating an exisiting onboard exchange VM to a 2003 Exchange Environment on different servers)
Can someone point me to correct way to implement this?
Correct Answer by Jaime Valencia about 7 years 3 weeks ago
Changing the Partner Exchange Server
if this helps, please rate
Overall Rating: 5 (1 ratings)
jamesbruce Tue, 09/29/2009 - 16:54
Thanks for that!. I do have one other question: Since the Current unity is running onboard exchange for VM only and is in its own domain, Is it possible to just change the store location as described in the document, OR, will I need to join the Unity server to the domain the Exchange server is in first, or just follow the instructions in the guide for Changing the Domain Controller and Global Catalog Server ?
Jaime Valencia Tue, 09/29/2009 - 17:23
If the domains are not the same the only way to change it is a unity reinstall, i believe there is a chapter for that in the reconfiguration guide
jamesbruce Wed, 09/30/2009 - 04:59
Thanks, saw that right after i posted the second question. I appreciate your help!
