SFP 100FX for GE and 100Mbps ports.
Answered Question
Sep 29th, 2009
I'm going to update 80% of LAN equipment.
The core switch will use this fiber card: WS-X6724-SFP - Catalyst 6500 24-port GigE Mod: fabric-enabled.
Some switches will continue using same speed, they have fiber with 100BaseFX.
I got two type of SFP, GLC-GE-100FX= and GLC-FE-100FX=.
Theses two of SFP can work with this fiber card ?.
Correct Answer by Leo Laohoo about 7 years 8 months ago
I don't know how accurate the Cisco documentation is, but the WS-X6724-SFP will not support GLC-GE-100FX and GLC-FE-100FX. You'll need the WS-X6148-FE-SFP.
Catalyst 6500/6000 Series
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#support1
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix (Table 9)
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp122766
Overall Rating: 5 (2 ratings)
iyde Tue, 09/29/2009 - 08:08
  • Silver, 250 points or more
You'll have to be careful!
GLC-FE-100FX= is the one you will need for Cat6500.
GLC-GE-100FX= is for Cat3xxx series of switches.
See http://www.cisco.com/en/US/products/hw/modules/ps5455/prod_module_series_home.html, even though it is not the best page, but the compatibility matrix for transceivers that Cisco used to have has apparently been deleted - at least my link to it is broken.
Correct Answer
Leo Laohoo Tue, 09/29/2009 - 14:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
iyde Wed, 09/30/2009 - 12:00
Right! My mistake; I did not pay attention to the fact that actually FastEthernet fiber SFP is NOT supported on the 6724 module - it's only gigabit.
Sorry about the wrong info.
Regards, Ingolf
luisveraza Wed, 09/30/2009 - 12:10
No problem, thank you a lot by your help.
It's ready.
Leo Laohoo Wed, 09/30/2009 - 15:14
  • Hall of Fame,
    2017 LAN, Wireless
No need to apologize. Like I said, you could be right and I could be wrong. It all depends on how often the documentations are updated.
Peace bro ... :)
