CME 4.1 issue
Answered Question
Sep 29th, 2009
I have an issue when i take a phone off hook i get a busy signal. I am sure it is something simple, but until i figure it out i am stuck. The phone generates the following error on the CME router:
*Sep 26 02:28:08.243: %CALL_CONTROL-6-APP_NOT_FOUND: Application telephony-service in dial-peer 20001 not found. Handing callid 5 to the alternate app .
I am assuming something with dial-peer configuration but cannot seem to get it resolve. Thanks in advance.
Correct Answer by Nicholas Matthews about 7 years 7 months ago
I'm not sure what could cause this problem - not familiar with this error message. You could start with removing telephony-service and ephone/ephone-dn, and re-adding. As well, a reload of the gateway.
-nick
Overall Rating: 2.5 (2 ratings)
Correct Answer
Nicholas Matthews Tue, 09/29/2009 - 10:01
  • Red, 2250 points or more
-nick
m-martynowski Fri, 10/02/2009 - 17:24
i reinstalled CME from scratch and loading a config i knew worked. It ran fine after that. Not sure what was wrong, (i.e bad CME install or bad config) but either way functioning fine. THanks
