%SYS-4-P2_WARN: 1/Blocked queue on gigaport 9
Sep 29th, 2009
I know the most common cause of these errors is a physical layer problem.
My question is...
Which port is this refering to as the switch in question only has 8 gigabit ports. 2 on mod 1 (WS-X4013) & 8 on mod 2 (WS-X4306).
Giuseppe Larosa Tue, 09/29/2009 - 12:22
Hello Colin,
I have seen the same error message my understanding is that the number is an internal number not directly related to port numbering as you noted.
Hope to help
c.walsh Wed, 09/30/2009 - 01:38
Giuseppe, thanks for your reply, how did you resolve the issue, did you need to reset the switch?
