6500 %SYSTEM_CONTROLLER-SP-3-MISTRAL_RESET
Sep 29th, 2009
we have installed a new switch and are received this message intermittently. message decoder does not have much info on this. Can someone provide more info or should we open a TAC case?
thanks
Overall Rating: 5 (1 ratings)
Lucien Avramov Tue, 09/29/2009 - 10:53
Mistral can be soft-reset for non-fatal errors, in which case you don't have to worry about it much.
Unless, you are seeing this reset like daily, there is nothing you need to worry about .No RMA needed.
