871w router lan connectivity - set up
Sep 29th, 2009
I think I may have found the correct forum here. Been trying forever to make good use of the router I purchased from Cisco market during CCNA class.(871w) I wiped the initial config , thinking I was good enough to do it by commands. Slick , huh? Well never been able to get SDM to work. Main reason seems to be VLANs and fact you can't put address on fe 0 to fe 3 ports. To be brief , I can open a terminal for commands log on to router and set an address on fe 4 , the wan port, and ping both ways to and from the laptop. Wish to do two things if I can get help. Set up VLANs so I can connect my local net. And reinstall SDM , which doesn't connect because there is no correct IP address for it. When I try to follow cisco manual / instructions it always directs towards configuration for switches regarding the VLANs and that is a whole different animal indeed.
Please anything may help, appreciate it. Thanks Doug M.
Overall Rating: 5 (1 ratings)
Lucien Avramov Tue, 09/29/2009 - 10:49
  • Red, 2250 points or more
Can you post the output of show run of your 871w and also tell me what subnet you want to use and on what interface you plugged your computer?
BeenyBoyz Wed, 09/30/2009 - 07:57
Okay , here is the output from the router as of now.
Router#show run
Building configuration... Add an access list en
Current configuration : 1114 bytes
alias
version 12.4 Create com
no service pad
service timestamps debug datetime msec Configure the A
no service password-encryptionive Archiv
!t
hostname Router
boot-start-marker
boot-end-marker
!S
no aaa new-modely
resource policy
ip subnet-zero
ip cefy syst
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.0 192.168.0.10 Define a login banner
ip dhcp excluded-address 172.0.1.0
network 192.168.0.0 255.255.255.0
boot
ip dhcp pool handoutsot parameters
network 172.0.0.0 255.255.0.0
bridge
no ip domain lookupoup.
interface FastEthernet0 Adjust syste
!b
interface FastEthernet1
interface FastEthernet2
call
interface FastEthernet3ure Call parameters
interface FastEthernet4
ip address 192.168.0.1 255.255.255.0 call history mib parameters
duplex auto
speed auto
interface Dot11Radio0 Global C
no ip addressn subcom
station-role root
interface Vlan1
ip address 172.0.1.10 255.255.0.0
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Router#
Note when I run "show vlans" it says no virtual vlans configured.
I want a wired connection to port(s) fe 0 to fe 3 but no vlans and no ip address can be set there, I have ip address for vlan 1 and ip address on fe 04 the wan port. Am connected to wan port (and console cable) to my laptop and can ping on the lan interface fe 4. Ips are not important to me as I can change it around anyway. Same for port numbers.
Just want to connect via fe 0 -3 to local server for now. Then I'll work on my internet connection and wireless network . Can't seem to get the sub-interface for fe 0 -3 going because no vlans to put a ip number on. Okay?
In case it is needed let you know I have no files in flash except the IOS 124-4.t7.bin .
Copied and then deleted them.
Hope the show run pasting wasn't too bad , and you can read it. If there is a better way to format , let me know I'll do again. Used copy / paste right to this window. Thanks for your answering back! Doug.
johnnylingo Tue, 09/29/2009 - 19:26
  • Bronze, 100 points or more
Check that you have "ip http server" in the config and have a username and password setup. Also you should be plugging a PC in to ports Fe0-3 (which will be in VLAN1 by default), then using the VLAN1 interface to access SDM.
BeenyBoyz Wed, 09/30/2009 - 08:05
I did try to reset SDM and set http server to secure but router is more misconfigured than that I believe. Those are the resets for SDM , but when I ran that configuration I still do not have any ip address on fe 0 through fe 3 . I did get an idea , what about if I used fe04 for the 10.10.10.1 address it looks for during set up? It may find the address and work like that?? Thanks- Doug.
Lucien Avramov Wed, 09/30/2009 - 08:28
There are a few things that are misconfigured on the show run you attached.
ip http server was missing but also the login local and the username privilege 15.
Make sure you follow the steps here:
The following example shows a configuration that contains the CLI commands Cisco SDM requires in order to operate.
hostname yourname
logging buffered 51200 warnings
username cisco privilege 15 secret 0 cisco
ip domain-name yourdomain.com
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-10/100 Ethernet$
ip address 10.10.10.1 255.255.255.248
description PC must be on the same subnet as this interface
no shutdown
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
line vty 0 4
privilege level 15
login local
transport input telnet
transport input telnet ssh
line vty 5 15
privilege level 15
login local
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/software/release/notes/SDMr25.html
BeenyBoyz Wed, 09/30/2009 - 08:49
Okay. A bit confused on why to keep setting up SDM though if I can not enter the commands to get the lines that says
" interface FastEthernet0
description ?????????????
description PC must be on the same subnet as the interface
no shut"
All the other lines I can configure , secure http server , telnet , login passwords etc.
Cisco has instructions to "reset SDM" for connecting but doesn't include putting IP on the fe 0 . That's where I am lost. Thanks for the link thought , there is lots to look at there. Mean time I'll set up sdm way I had done it before and paste the output of show run again so you can see what I mean. Thanks.
BeenyBoyz Wed, 09/30/2009 - 09:18
Here is the config with reset SDM .
Notice I changed my Fe 4 ip to try to connect sdm that way. Doesn't seem to like it. SDM install tries to connect and then says error 404 in browser. Also do you see where i do not have an IP address on fe-0 like your config did? That's where sdm want to connect.
Current configuration : 3005 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp excluded-address 172.0.1.0 172.0.1.10
ip dhcp excluded-address 10.10.10.0 10.10.10.10
ip dhcp pool wireroute
network 10.10.10.0 255.255.255.248
no ip domain lookup
crypto pki trustpoint TP-self-signed-3962786491
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3962786491
revocation-check none
rsakeypair TP-self-signed-
crypto pki certificate chain TP-self-signed-
certificate self-signed
quit
username beeny privilege 15 password 0 cisco
duplex auto
speed auto
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0
54.0
station-role root
interface Vlan1
ip classless
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Router#
Does any of this make sense or should I give up on it!
iyde Sat, 10/03/2009 - 03:17
  • Silver, 250 points or more
FastEthernet 0, 1, 2 and 3 are switchports, i.e. layer 2 ports. As in all (?) Cisco switches, layer 2 switchport by default are in VLAN1, the default VLAN. This means that if you try to connect to the rotuer via FastEthernet 0-3 you'll have to do the matching IP configuration under interface VLAN1, which in your example is IP net 172.0.0.0/16 and IP address 172.0.1.10
So try set your PC IP address to something in the 172.0.0.0/16 and then connect to 172.0.1.10
BeenyBoyz Mon, 10/05/2009 - 10:50
Hi there!
Thanks for the info. It does seem to be that simple. Am trying it out , give me a bit if time and I'll let you know if it works. Thanks again for posting reply! I may not get right back to you for a day or so though.
