Cisco2509 Terminal Server
Sep 29th, 2009
please need your help.
when trying to connect to a router from the terminal server i got the following
LAB_TermSrvr#c1
Trying c1 (10.1.0.1, 2001)...
% Connection refused by remote host
i believe that the 2509 been configured correctly.
thank you.
Lucien Avramov Tue, 09/29/2009 - 12:16
  • Red, 2250 points or more
your configuration is fine. Are you sure there is a port 2001?
On the host using port 2001, do a show run and check the "line con0" command, make sure there are no access-lists applied.
mhasabal Tue, 09/29/2009 - 12:23
here is my lines config:
line con 0
logging synchronous
transport output telnet
line aux 0
line vty 0 4
privilege level 15
password 7 (cisco)
logging synchronous
transport input telnet ssh
line vty 5 15
scheduler allocate 20000 1000
there is no ACL
ToddWarren Tue, 09/29/2009 - 12:58
Can you paste output of SHOW LINE? Never mind. Got it in the attachment.
