Music on Hold (MoH) max length of time - UC5X0
Sep 29th, 2009
How many minutes can a specific music on hold file be before it loops.
Saurabh Verma Tue, 09/29/2009 - 14:19
There is no upper limit to the size of a custom music-on-hold file. However, note that the engineering team has not tested out multiple sizes. The size of the default file is 485KB. About 500KB gives you 2 minutes of g711 pcm. The file itself is not read all at a time, instead it is read is small chunks. If the file is large, there will be multiple read attempts on the CF and that could lead to a performance issue. Although engineering does not have any recommendations, I would suggest that you keep it close to 500KB.
Steven Smith Tue, 09/29/2009 - 14:32
You could also use an external audio source which would make no limit on the UC500.
