Nexus 5K w/4.1(3) "default interface"
Sep 29th, 2009
Got two new boxes that I am thoroughly impressed with. What am I missing? I want to reset Ethernet interfaces to default status as in IOS: (config)# default interface f0/1 <cr>. I've search command reference syntax high and low. I've learned more of the CLI trying to find something that would return an interface configuration to its default. Which is good but... I do not trust issuing a set of 'no' prefixes to configuration lines. That is not smart in IOS and I suspect not in NX-OS also. Help. Thanks.
Overall Rating: 5 (3 ratings)
russellra Wed, 09/30/2009 - 10:02
Craig, thanks for the suggestion but this syntax fails on the Nexus with 4.1.3. I'm still looking. I'll likely be embarrased with the obvious simplicity once I/we find it. - R
philmcgregor Sun, 03/28/2010 - 22:08
Having the same issue.
Would really like the piece of mind of being able to easily set these interfaces back to their default state.
Nicholas Taube Mon, 04/26/2010 - 18:47
Has anyone had any luck yet with a "default interface" command on the Nexus platform?
This has been a question of mine since day one and I have yet to find an answer.  The "no int instance" is not a working command on the Nexus.
iceteanolemon Thu, 06/03/2010 - 10:14
I try to do a "no interface" and get negative results. It does however let me step my way through the command which makes me think it was layed out to be the command to make work. It just doesnt work though
No default interface no "no interface" i cannot do anything to clear it in one command?
VB6-DC-CR003(config)# no interface e1/10
Invalid range at '^' marker.
VB6-DC-CR003(config)# no interface ?
  ethernet      Ethernet IEEE 802.3z
  loopback      Loopback interface
  mgmt          Management interface
  port-channel  Port Channel interface
  vlan          Vlan interface
VB6-DC-CR003(config)# no interface ethernet ?
  <1-18>  Slot number
VB6-DC-CR003(config)# no interface ethernet 1?
  /       Slash separator
  <1-18>  Slot number
VB6-DC-CR003(config)# no interface ethernet 1/?
  <1-128>  Port number
VB6-DC-CR003(config)# no interface ethernet 1/10?
  ,        Multi range separator
  -        Range separator
  .        Sub interface separator
  <1-128>  Port number
n7000-s1-dk9.4.2.1
firemtngems Mon, 10/25/2010 - 16:31
I don't suppose anyone has answered this, but I am finding the same issue on version 5.0(3) on the N7010.  Please post if you know how to put an interface into a defaulted state (I give points!).
Mike
Robert Taylor Mon, 10/25/2010 - 21:26
For n5k, there is no feature added for this yet (although there has been talk of syncing the feature added by n7k developers).
For n7k, you'll get this feature when 5.1.1 comes out.  The feature request "CSCsz17197" accomplishes this, although the bug info shows some misleading information.  It is NOT YET available in any releases on cisco.com, as of today.
I tested this on pre-launch code, and it DOES exist (global config mode) with CLI of:
RP_7k1(config)# default interface ethernet 2/2?
  -        Range separator
  <1-128>  Port/slot number
For now, you should be able to issue "switchport" or "no switchport" (depending on your current state) to flap it back to a vanilla config.
ex: If currently in "router port" mode, then issue "switchport", and then "no switchport" to get it back into routed mode, but with a vanilla config.
Unfortunately, this workaround does not work on n5k.
Hope this helps,
Rob
haidar_alm Wed, 07/10/2013 - 03:02
Having the same issue on our N5Ks running version: 4.2(1)N1(1).
Has this been resolved int later versions?
Output:
N5K_CR1(config)# no interface ethernet ?
  <1-255>  Slot/chassis number
N5K_CR1(config)# no interface ethernet 101?
  /        Slash separator
N5K_CR1(config)# no interface ethernet 101/?
N5K_CR1(config)# no interface ethernet 101/1/?
  <1-48>  Port number
N5K_CR1(config)# no interface ethernet 101/1/31 ?
  -      Range separator
N5K_CR1(config)#
N5K_CR1(config)#
Havin
daniel.herrmann... Wed, 06/22/2016 - 04:05
Based on my answer on [email protected], I post the same answer here:
It actually depends on the NX-OS version running on the switch (and hence the switch model). Starting with version 6.0(2)N2(1), the default interface command has been added to the nexus world. Compare the release notes of this version.
As far as I know, previous versions do not support this or any similar command.
However you won't be able to run NX-OS 6 or later on the 5010 or 5020 platform, it requires the 55xx platform.
