MWI Request failed
Answered Question
Hi All,
I having issue with the MWI syncronization for my suscribers, it is not be notified on time or not show as it is:
Description: the light on the phone for the voice mail is not turning on so he does not know when he gets a new voice message
Event Viewer is showing me :
Cisco Unity-CM TSP device 82 (Cisco Unity port 31): An attempt to turn OFF the message waiting indicator (MWI) for extension 24925 failed because a collision occurred with an incoming call on the same port.
I just use the Unity tool - Bulk Suscriber but when I am going over a messages parameters of a user and I press the Refresh Status, this keep showing me MWI Request failed.
Cisco Unity 4.0 Build 4.0(5)
Please your suggestion
Andres
Correct Answer by Bradford Magnani about 7 years 8 months ago
Andres,
The error is telling you exactly what's happening;
A collision can occur if you have your phone system configuration such that you have MWI dialing out on ports that also are configured to accept calls.
Make sure you're configured per the installation guide and make sure all MWI ports in UTIM are only configured for outdial and that in CCM, the MWI ports are not included in the line group.
Hope that helps,
Brad
Overall Rating: 5 (1 ratings)
Correct Answer
Bradford Magnani Tue, 09/29/2009 - 14:49
  • Cisco Employee,
Andres,
Hope that helps,
Brad
Tray Stoutmeyer Wed, 09/30/2009 - 06:45
  • Cisco Employee,
In addition make sure the CUCM doesn't have any line groups that include your MWI dial out only ports so they are never presented with a call by CUCM.
Tray
