What hardware should I get for CCNA Voice
Sep 29th, 2009
I passed my CCNA and want to learn more about voice. I have several 3640 routers, a 2610XM routers, and a bunch of 2950 switches. What router should I use or get for my CCNA Voice home lab? I already have two 7940 Cisco IP Phones, a VIC-2FXO card and a NM-2V card. Is there any other equipment I should acquire?
srue Wed, 09/30/2009 - 06:06
  • Blue, 1500 points or more
do you plan on pursuing your ccvp also? that decision might affect what you would want for your ccna-v.
chull6509 Thu, 10/01/2009 - 15:06
I will not doing voice beyond CCNA Voice. I am working on my CCNP, hence all the routers (7) and switches (7), and have had a semester of voice at the local college and figured I would get that certificate now.
b.gamble Tue, 10/06/2009 - 03:15
The CME labs on PEC are very good for the CVOICE exam, which, as I understand it, is half of the CCNA Voice. If you work for a Cisco partner try PEC first. You won't have to purchase anything.
