Can you PAT TFTP with ASA Phone Proxy?
Sep 29th, 2009
I have an install where I will only be provided two external addresses for an ASA that will be using the UC Phone Proxy feature. I would like to have a third IP to use NAT for tftp but that option is not available.
Am I able to use PAT against the external (outside) interface address for tftp for the UC Phone Proxy feature?
e.g.
object-group service tftp udp
port-object eq tftp
object-group network cucm70-tftp-external
network-object host 1.2.3.4
object-group network external-mediaterm
network-onject host 1.2.3.254
object-group network cucm70-internal
network-object host 10.9.8.7
object-group network internal-mediaterm
network-onject host 10.9.8.254
access-list outside_access_in extended permit udp any object-group cucm70-tftp-external object-group tftp
access-group outside_access_in in interface outside
static (inside,outside) udp interface tftp 10.9.8.7 tftp netmask 255.255.255.255
nat (inside) 1 10.0.0.0 255.0.0.0
global (outside) 1 interface
ctl-file ctl_ucproxy_file
record-entry cucm-tftp trustpoint ucproxy_trustpoint address 1.2.3.4
no shutdown
media-termination mediaterm
address 10.9.8.254 interface inside
address 1.2.3.254 interface outside
phone-proxy sample-phone-proxy
tftp-server address 10.9.8.7 interface inside
tls-proxy sample-tls-proxy
cipc security-mode authenticated
