7960 Network Settings
Sep 29th, 2009
Hi all,
I am trying to change the network speed on a 7960 however when I try to access the "network setting" menu on the phone it is grayed out. I have enable the "Settings Access" on CM, reset phone, and tried unlock using **# to no avail. I have just stepped into the support role for this network and I am unsure of the restrictions which may have been placed.
Any assistance would be greatly appreciated.
testeven Fri, 10/02/2009 - 16:14
Hi!
Try unlocking the phone settings with **#** and disabling the DHCP option. After that the keys should be active.
HTH!
Teresa.
