unable to access GUI of IPS through IDM
Sep 29th, 2009
when i try to access my intrusion prevention system (IPS) GUI through IDM then i got this message
" Error Connecting to sensor . Failed to load sensor - errSystemError-ct-sensorApp.378 not responting , Please check system processes . the connect to the specified lo::clientpipe failed . Exiting IDM"
Please tell me how to solve this problem
ddevecka Mon, 10/05/2009 - 07:58
What type on sensor are you using? Also have you tried the IME?
Dan
andrey.dugin Mon, 10/19/2009 - 01:17
  • Bronze, 100 points or more
If this problem is appeared only in the case you use IDM or IME but CLI is OK try to re-generate the tls certificate on the sensor. May be it is expired.
zubair-shaikh Mon, 10/19/2009 - 04:24
Hi Umakanth
Here you go!
Error Message
Possible Cause
These error messages appear when you run the show tech support command and Analysis Engine is not running.
Recommended Action
Verify Analysis Engine is running and monitor it to see if the issue is resolved.
To verify Analysis Engine is running and to monitor the issue, follow these steps:
Step 1 Log in to the sensor.
Step 2 Verify that Analysis Engine is not running:
sensor# show version
MainApp N-2007_JUN_19_16_45 (Release) 2007-06-19T17:10:20-0500 Running
AnalysisEngine N-2007_JUN_19_16_45 (Release) 2007-06-19T17:10:20-0500 Not Running
CLI N-2007_JUN_19_16_45 (Release) 2007-06-19T17:10:20-0500
Check to see if AnalysisEngine reads Not Running.
Step 3 Enter show tech-support and save the output.
Step 4 Reboot the sensor.
Step 5 Enter show version after the sensor has stabilized to see if the issue is resolved.
Step 6 If Analysis Engine still reads Not Running, contact TAC with the original show tech support command output.
Please rate if this post helped you? Thanks
angel.huamani Mon, 10/26/2009 - 19:38
Zubair,
What happen if after reboot the analysis engine is Running, but in a few hours again the Analysis engine is Not Running?
Any things? Any URL?
Angel H.
rma15676cisco Tue, 10/27/2009 - 05:54
I think what he is saying is the same thing what I am experiencing.
when you can't connect through the GUI in the above named case, it will fix that by restarting the sensor. ( analysis engine is running once again )
but after some time it seems that the engine shuts of resulting in not being able to connect.
