UCCX HA CRS Engine Error on second Node
Sep 29th, 2009
I have UCCX HA deployment. The firts node is working fine. But the second node when I go to Control center to enable CRS Engine fails. The error message is "Unable to create CTI"
What Can I do?
atalante Wed, 09/30/2009 - 03:08
Check your network interface. The first one must be unable, and the 2nde one must be disable. In the advance settings, check the order
Miquel Capdevila Wed, 09/30/2009 - 08:38
The 2ond Network interface is disabled.
I have a cluster of UCCX. One server is Publisher, but the second node appears as Add-on type in Control Center menu.
neoxbusnext Wed, 10/14/2009 - 10:44
If Control Center showing wiht Add-on , that mean CCX engine are not start on that server.
atalante Thu, 10/15/2009 - 08:04
Check the CTI port created on CUCM, and remove all devices which are not registered or rejected.
And try again.
Which release did you install ?
If UCCX 7 SR3 with OS SR9
Remove the SQL HOTFIX 8822 and try again.
