LMS 2.6 Latest patches - Syslog issue
stevejhale
The syslog collector is still collecting and I can see the file size increasing (nearly 30gb) in syslog.log. However when I try to run a syslog 24 hour report it returns no values. Also in the device centre view I do not see any syslog entries. However on the slave both these items are still working. How do I fix this issue?
Lucien Avramov
Level 10
Level 10
Do you want to reduce the syslog.log size, here is how:
You can enable log rotation for the syslog which I recommend you have enabled in the future. If needed you can delete the previous file as well.
In the /CSCOpx/bin/ directory run : perl logrot.pl -c
You can try to delete the syslog.log (or rename if it has already some logs on it) from the server and restart daemon manger #
To Stop #
net stop crmdmgtd
To Start #
net start crmdmgtd
If you want to troubleshoot the syslog issue, it may be easier on a smaller file, so go ahead and rotate at least the file to something smaller that can be edited by a text editor so you can see whats happening.
Check if there is something listening on port UDP 514.
Use netstat -a -n -o -b to see what process that is.
Check if crmlog service is started or stopped. You can start it with net start crmlog.
Lucien Avramov
Level 10
Level 10
To Stop #
net stop crmdmgtd
To Start #
net start crmdmgtd
