Standby Console on VSS system active
Sep 30th, 2009
I configured a VSS system, VSL is running and i connot see any problem. Only issue i cannot explain is that console of standby system is not inactive.
I would expect that it says :
Standby console disabled.
I have seen this before on other VSS systems. Any ideas ?
rducombl Wed, 09/30/2009 - 02:07
  • Cisco Employee,
There is a CLI config you can apply on the active to enable standby console.
it is in redundancy main cpu mode :
standby console enable :
SW(config)#redundancy
SW(config-red)#main-cpu
SW(config-r-mc)#standby console enable
but this is hidden not visible in running config but you can disable it using :
SW(config-r-mc)#no standby console enable
However it
Roland
owalter Wed, 09/30/2009 - 03:57
Hi Roland,
Thanks for your reply.
I did not know that this command is hidden.
I thought as long as
standby console enable is not
set in the red. config mode it
cannot work.
What is the default of this setting after the system comes
up, and what happens after a reload when i enabled standby console ?
