ES20 - Port Queues
Sep 30th, 2009
I have a 7609 with a WS-X6748-GE-TX. When I show the port capabilities I
can see rx-(1q8t), tx-(1p3q8t)
If I show queueing on an interface I see all the WRED and WRR queue
configuration.
This is great, I can make changes and view changes.
I also have an ES20 and ES20+ line card in the chassis. When I show the
port capabilities I see x-(NotDef-t), tx-(NotDef-t)
When I show queueing on an interface I see nothing for the ES20. For the
ES20+ I get
Interface GigabitEthernet1/1 queueing strategy: Weighted Round-Robin
Port QoS is enabled
Port is untrusted
Extend trust state: not trusted [COS = 0]
Default COS is 0
So the ES20 tells me nothing and the ES20+ only shows a subset of what I
see with the WS-X6748-GE-TX.
Is there something I am missing in my config to show what queues I have
available on the ES line cards '(1p3q8t)'
From reading the line card configuration guides I can see ingress
scheduling is not supported and egress is but when I configure a egress
policy-map with my random-detect configuration I still see no queueing
info for the ports.
Anthony
Overall Rating: 3 (1 ratings)
Laurent Aubert Wed, 09/30/2009 - 17:53
  • Cisco Employee,
Hi Anthony,
ES and 6748 are two completely different type of LC based on different hardware.
ES20 LC support 16K hw queues to give you an example in addition to H-QoS, shaping,..
You should use the show policy-map interface command instead.
Laurent.
