6500 (bridge # protocol ieee)
Sep 30th, 2009
Hi!
I'm actually working in a migration from a 5500 switch to a new 6509 Switch, and one of the features (that customer think it's not in use anymore, but anyway, he needs it migrated to the new 6509-E Switch) is the bridge protocol...
Every piece of the configuration seens to work fine, except for the protocol ieee:
bridge 2 protocol ieee
Instead of "ieee" I only have options for DEC, IBM and VLAN-BRIDGE, but no IEEE.
I've saw on Cisco Website (http://www.cisco.com/en/US/docs/ios/ibm/command/reference/ibm_b1.html#wp1011832) that the IEEE was based on the DEC protocol, so I'm thinking of going for it and see what happens.
IOS upgrade (at least for now) is out of question, switch is working already, and will not be able to do any upgrade now.
Any advice?! DEC will work fine?!
Here's the rest of the configuration, just in case:
source-bridge ring-group 600
dlsw local-peer peer-id 10.96.0.111
dlsw remote-peer 0 tcp 10.52.0.121
dlsw remote-peer 0 tcp 10.52.0.131
dlsw duplicate-path-bias load-balance
dlsw timer explorer-wait-time 3
dlsw bridge-group 2
And the hardware:
Switch: 6509-E
Supervisor: WS-SUP32-GE-3B
IOS: s3223-advipservicesk9_wan-vz.122-18.SXF16.bin
Thanks!!!!
Giuseppe Larosa Wed, 09/30/2009 - 05:29
  • Hall of Fame,
    Founding Member
Hello Caue,
according to feature navigator DLSW+ is supported with your IOS image and your hardware.
So I would give a try to dec as STP protocol for the bridge-group.
However, I see the following:
that make me think there is L2 redundancy so it may be safer to try it in a maintanance window
Hope to help
Giuseppe
Caue W Wed, 09/30/2009 - 06:25
Thanks Giuseppe!
I will try that...
But it's a huge fail if Cisco says that it supports everything and leave the most used protocol out of the IOS... I just can't believe that!
Anyway... I'll give a shot and let you know!
Cheers,
Caue Wailemann
Giuseppe Larosa Wed, 09/30/2009 - 06:53
  • Hall of Fame,
    Founding Member
Hello Caue,
in any case you can move the DLSW on a software based router if you have problems with the C6500.
test in a maintanance window.
Hope to help
Giuseppe
Francois Tallet Thu, 10/01/2009 - 09:30
  • Gold, 750 points or more
The "ieee" protocol is supported on switchports. Even on the 5k, it was not recommended to use ieee on the RSM btw, check the "fall back bridging" section of this old document for an explanation: http://www.cisco.com/en/US/products/hw/switches/ps679/products_tech_note09186a00800a7af2.shtml#fallback
I recommend you use the vlan-bridge protocol instead. It has been designed on purpose for being run on the L3 interfaces of a bridge.
Francois
