Maximum Translation Rules in CUCM
Sep 30th, 2009
Hi Gurus,
Is there a maximum number of Translation rules that can be configured on CUCM i.e. a design or a suggested/tested limit?
I have tried drilling through various documents and have found other limits like CTI RP's etc but none yet for Translation Pattern.
Thanks for the help guys!!
Overall Rating: 4 (2 ratings)
Jaime Valencia Wed, 09/30/2009 - 06:40
There are no hard numbers on how many TPs you can have, the maximum depends really on the HDD since every entry takes some HDD space.
Obviously if you do create a large number like 10K you might need to tweak the DB initialization numbers to avoid problems
Also careful design of CSS and partitions need to be taken as otherwise it might cause delay
if this helps, please rate
VoipRocks Tue, 10/06/2009 - 07:44
Hi Java,
Thanks for the response. Would you care to provide any links/resources where I can find out how to 'tweek' the DB initialization numbers?
Cheers mate!
Jaime Valencia Tue, 10/06/2009 - 08:46
CUCM service parameter:
System Initialization Timer
dakeller Mon, 03/21/2011 - 14:53
Cisco does not have a hard limit on translation patterns.  We have tested up to 5000 in test, so you may see the number 5000 as the limit.  We are looking at testing higher numbers for supported translation patterns.  But the best resource for scaling is to use the capacity tool. Cisco does not expect to see a CUCM cluster that has 50K xlates and very few other devices or route patterns.  Translation use system resources and the capacity tool takes a cluster and solution view of all aspects of the deployment.
Dan Keller
Technical Marketing Engineer
