Jaime Valencia Wed, 09/30/2009 - 09:30
There is no config for that, once the PVDMs are loaded and the PRI/FXS/FXO is loaded by the IOS it allocates the necessary channels
java
if this helps, please rate
Jaime Valencia Wed, 09/30/2009 - 10:24
Not sure what you mean if you don't provide a clear explanation
If you mean you want to share voice termination and XCODER it's possible (As long as you have enough DSPs for both of course)
java
Adrian Saavedra Wed, 09/30/2009 - 10:30
Hi Celso,
Sorry for not follow up the other post about this topic.
As Java said, it doesn't need configuration.
To answer your last question:
You allocate DSP resources either to voice termination of the voice trunk group or to the DSP farm. Occasionally these allocations can conflict.
If you previously allocated DSP resources to voice termination (this must be done first) and you now try to configure a DSP farm, you might find that insufficient DSP resources are available. Conversely, if you previously allocated DSP resources to a DSP farm and you now try to configure a trunk group, you might find that insufficient DSP resources are available.
Hope it helps, if it does please rate.
Best regards,
- Adrián.
cfajardo1_2 Wed, 09/30/2009 - 11:03
is it possible to provide sample configuration of the above mentioned scenario?
thanks
cfajardo1_2 Wed, 09/30/2009 - 18:52
hi java,
i couldnt see any config of mix voice termination and transcoder/conf bridge.
Jaime Valencia Wed, 09/30/2009 - 20:59
again... there is NO config for voice termination. Adrián also explained this.
You DO NEED to configure XCODER or CFB, for that, refer to the link
java
cfajardo1_2 Wed, 09/30/2009 - 22:38
pls have a look on my other post titled
'pvdm2 enable on 2800 main board'
