CDR error "10012.Database Error. Contact system administrator"
Sep 30th, 2009
I enabled CDR in the CCM 7. But i m not able to pull the information through CAR. I m getting this "error 10012.Database Error" If any body faced this same error befor pls try to help me to resolve this issue.
and i try to do complete some trouble shooting steps also.
Sunish
virverma Wed, 09/30/2009 - 10:19
1. With root access, backup the existing file of /usr/local/cm/conf/dbl/prefs.xml on CUCM server. (i.e. cp /usr/local/cm/conf/dbl/prefs.xml /usr/local/cm/conf/dbl/prefs.xml.BAK)
2. Manually update/modify /usr/local/cm/conf/dbl/prefs.xml. Change the hostname & informixserver values for the 'jdbcurl_car' entry to match that of the hostname & informixserver values listed in 'jdbcurl' entry. Save the changes and exit.
For example, if you see prefs.xml with something like:
Change jdbcurl_car line to:
This can be done by:
/usr/local/cm/bin/pryftool --system cm --hive dbl --set jdbcurl_car="jdbc:informix-sqli://NEWHOST:1500/car:informixserver=newhost_ccm6_1_2_1000_13;user=dbcarsch;IFX_LOCK_MODE_WAIT=20"
3. Afterwards, restart 'Cisco CAR Web Service' & 'Cisco CAR Scheduler' services.
