Sustained DTMF Tone
Sep 30th, 2009
Is there a way to make the 794x phones generate a sustained DTMF tone? For example, I need the "*" key to generate a constant tone for 650ms; however, it is only generating a 10 to 20ms tone even though I'm depressing the key. Thanks.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Wed, 09/30/2009 - 14:50
  • Hall of Fame,
    Founding Member
Sorry, there is no way, in the cisco architecture DTMF duration is always normalized.
I'm afraid you will have to use one of these small DTMF dialers, that are quite hard to find now.
Nicholas Matthews Thu, 10/01/2009 - 04:35
  • Red, 2250 points or more
Hi Tim,
If you have CUCM, and depending on your protocol, you may be able to change this.
For instance, you can change a service parameter regarding H323 to make the DTMF duration longer.
There are ways to do it, but it is dependent on the protocols and devices in your call flow.
-nick
Paolo Bevilacqua Thu, 10/01/2009 - 06:20
  • Hall of Fame,
    Founding Member
The thing is that users want to send long digits only when necessary by the connected IVR application.
They do not want to change the default digit duration for all calls.
Nicholas Matthews Thu, 10/01/2009 - 07:32
I still wouldn't underestimate the creativity you can do with the settings that exist. The default DTMF duration is adjustable in many places, and there's still a good chance you can get this to work. As well - I don't think very many people would ever notice that all of their DTMF is 650ms. From my experience, the average user's natural duration is somewhere between 200-400ms anyway.
-nick
Paolo Bevilacqua Thu, 10/01/2009 - 07:40
  • Hall of Fame,
    Founding Member
I think I have not explained myself correctly.
This is not about changing defaults, that are fine.
Some IVR applications require you to enter long tones for certain functions, E.g. with certain long distance calling card, you enter a "longpound" to recall a dialtone at any stage of the call.
The natural way to do this is keeping the key pressed, unfortunately that doesn't work with cisco phones and users are disappointed.
May be the OP could clarify if my understanding is correct.
Nicholas Matthews Thu, 10/01/2009 - 08:51
That's interesting - I've done quite a bit of DTMF work but never heard of an application that required a particularly long tone. +5 for this.
There's a whole spec lined out in ITU Q.24 which specifies the minimum length, frequency accuracy, etc. Technically any device that requires anything else would be out of specification.
-nick
Paolo Bevilacqua Thu, 10/01/2009 - 09:16
  • Hall of Fame,
    Founding Member
Here a page from Cisco TLC/IVR that describes how to intercept (and generate) long tones and act appropriately.
http://www.cisco.com/en/US/docs/ios/voice/tcl/developer/guide/tclivrv2_ch3.html
Why this is necessary? Because when using calling card services we want:
1. to only make a single call to the access number, no matter how many card calls are then made.
2. to be able to use regular dtmf for any IVR we may call into.
3. To have a safe way to be returned to the main prompt, even if the called party doesn't hang-up (stuck call).
Hence the need for long tone, usually pound.
That is not against the specifications because the standard dictated a minimum duration for the digit to be recognized during dial phase, not what you do with tones after the call is made.
tim_roper Thu, 10/01/2009 - 12:23
We have a specific transfer need. An internal user (User-I) is talking to an external user (User-E), and User-I wants to transfer User-E to another company on the PSTN. Our carrier will recognize a DTMF tone that is 650ms or longer and give User-I a second dial tone. User-I can then dial the other company and complete the transfer. This service is called Transfer and Release (TnR). Unfortunately, the carrier will not accept a sequence of different DTMF tones. Thanks for all of the input so far.
Paolo Bevilacqua Thu, 10/01/2009 - 13:05
  • Hall of Fame,
    Founding Member
I think this can be done with a TCL/IVR script. In turn this require you to run H.323 or SIP to the GW.
If you are interested in having it custom developed, contact me at the address present in my profile.
tim_roper2 Thu, 10/01/2009 - 13:08
Unfortunately, I won't be able to release the b-channels from the original call unless I can issue the DTMF tone during that call...the carrier switch listens for the DTMF tone and pulls the call into a virtual trunk group for transfer.
Paolo Bevilacqua Thu, 10/01/2009 - 13:17
  • Hall of Fame,
    Founding Member
Yes, I think it can be done with an appropriate script. Are the calls to be TnR incoming, outgoing or either for user-I ?
tim_roper Fri, 10/09/2009 - 10:40
Either. Currently, I have a request to the BU to provide an answer, so I will keep everyone posted. Thanks.
Paolo Bevilacqua Fri, 10/09/2009 - 11:12
  • Hall of Fame,
    Founding Member
Let us know.
Although I'm not sure what is the advantage of doing this type of transfer over a regular ones, beside not tying up channels.
Nicholas Matthews Thu, 10/01/2009 - 18:44
What's the topology? You may be able to avoid a custom TCL script by changing DTMF durations for your calls.
Me and Paulo will disagree on this one because of our experiences - but I really try to avoid running custom TCL whenever possible. It opens up a world of possibilities in terms of new problems. On the other half, it also lets you do some cool things. Most people err on the side of caution with their voice networks.
-nick
Paolo Bevilacqua Fri, 10/02/2009 - 03:01
  • Hall of Fame,
    Founding Member
I haven't seen any new problem caused by TCL/IVR scripting so far, be that Cisco-supplied or other properly written scripts.
But I have seen them doing cool things like delivering ANI on CAS circuits, recording prompts directly from any phone, handle internal and external calls in different ways, dialing with pauses and more.
All things that a $300 PBX does without a problem, but Cisco mysteriously doesn't. Fortunately TCL/IVR is a great solution for many issues.
On the other hand I've seen many voice (and data) network to be brought to their knees by buggy Cisco software.
I do not think that changing the default digit duration is a good solution, becuase that would change it for all calls, eg to enter a 16 digits credit card number would take 10 seconds, making all operations awkward.
tim_roper Mon, 10/12/2009 - 05:34
Can you please explain your comment to change DTMF durations for your calls? I am using H323 gateways, and I can't seem how to do it for a PRI interface. There are a few commands for E&M, FXS and FXO interfaces, but not for ISDN PRI voice ports. Thanks, Tim
Nicholas Matthews Tue, 10/13/2009 - 05:59
For H323 you will want to change it on the device sending the digits. The h245 methods use include a parameter for digit length. If you have CUCM, there is a service parameter for this if you search for it.
-nick
tim_roper Tue, 10/13/2009 - 08:59
Changing the H225 DTMF Duration service parameter did not make any difference. The H225 DTMF Duration specifies the duration of outbound DTMF digits for H.323 devices.
Nicholas Matthews Wed, 10/14/2009 - 17:27
If your gateway is H.323 then it should take effect - I've confirmed that in the lab before for similar issues.
-nick
Nicholas Matthews Mon, 10/19/2009 - 14:04
CUCM has this service parameter that I've confirmed works with gateways:
H225 DTMF Duration
Default is 100ms.
-nick
