E1 R2 between 2811 and Nortel 11C receiving dialed digits
Sep 30th, 2009
Hi, i have a problem. When i make calls from Callmanager to PBX Nortel works. But calls from PBX Nortel to Callmanager there a delay a couple seconds then i hear dial tone ,i dial the number and works.Any idea?
PBX Nortel--E1R2---GW2811--Callmanager
PBX Nortel 11C rls 81
Gw2811 IOS c2800nm-spservicesk9-mz.124-3i
Callmanager 5.1.3
Brandon Buffin Wed, 09/30/2009 - 11:43
Sounds like you need an inbound dial peer with "direct-inward-dial" such as:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
Hope this helps.
Brandon
Paolo Bevilacqua Wed, 09/30/2009 - 14:48
As Brandon said, this is caused by need of direct-inward-dial. may be you have another pots DP being matched before DP 1, need to check config.
cristian.munoz Thu, 10/01/2009 - 06:11
Dear Brandon
Now is working. I saw in the debug voip dialpeer that the PBX send a five digit. I put a num-exp and all works.
Thanks a lot!
