Ping through VPN
Sep 30th, 2009
I have two routers Rv082. I made a gateway to gateway tunnel between the two of them. From a computer behind my first router I can ping my other router.
But when I try the same thing from a computer behind my second router, I cannot ping the first router.
Do you have any idea of the problem.
Thank you
platinum_jem Wed, 09/30/2009 - 18:53
Some info on your configurations, plus IP addresses would aid in the troubleshoot.
bruno.lach Thu, 10/01/2009 - 04:13
The Tunel configurations are :
Tunel Name : Test
Interface : Wan1
Enable : checked
Local Security Gateway Type : Ip Only
IP Address : XXX.XXX.XXX.XXX
Local Security Group Type : Subnet
IP address : 10.0.0.0
Subnet Mask : 255.255.255.0
Remote Security Gateway Type : Ip Only
Remote Security Group Type : Subnet
IP address : 192.168.0.0
Keying Mode : IKE with Preshared key
Phase1 DH Group : Group1
Phase1 Encryption: DES
Phase1 Authentication : MD5
Phase1 SA Life Time : 2800 seconds
Perfect Forward Secrecy : checked
Phase2 DH Group : Group1
Phase2 Encryption: DES
Phase2 Authentication : MD5
Phase2 SA Life Time : 3600 seconds
Preshared Key : test
In the advanced section I checked the following options :
NetBIOS broadcast
Keep-Alive
Aggressive Mode
I have try this three options checked and unchecked.
I hope this can help!
