Java.lang.NullpointerException
Sep 30th, 2009
  • Silver, 250 points or more
Any one seen this. It comes in CRS editor every time I am trying to create a new variable or modify a variable in an existing script.
"java.lang.nullpointerexception"
Overall Rating: 5 (4 ratings)
adignan Wed, 09/30/2009 - 20:30
  • Blue, 1500 points or more
Is it with all scripts, or just a particular script?
Abdulbaseer Mohammed Wed, 09/30/2009 - 20:39
Well after several times of reinstall and doing some research found out its a bug. The fix is strange.
Just click on CRS editor icon, properties, compatiability tab select to run as windows 2000.
Fixes the problem.
bug: CSCso68954
webberr Fri, 10/02/2009 - 04:14
Thanks so much for posting this - never would have found that!!! This worked great on CCX Editor version 7.0(1.168).
For those looking, assuming you installed with the default settings the .exe can be found in:
C:\Program Files\wfavvid
and the file is named:
CiscoUnifiedCCXEditor.exe
Follow the steps above and relaunch the app.
Rob.
rcrumm_2 Mon, 10/26/2009 - 16:44
I did the above and it fixed me as well.
Thanks!
Randall
Abdulbaseer Mohammed Mon, 10/26/2009 - 20:22
I spent few days looking like an idiot (to myselft) at client site eventually getting it fixed.
Glad it helped you all too.
Please rate if it helps.
Baseer.
