ASA : Cannot ping the default gateway
Sep 30th, 2009
Hi all,
I cannot ping my default gateway, and my default gateway connot ping me.
I've got a ASA 5520 with a 8.0.4 OS version.
I've configured the ACL on the interface with the
access-list int1-in extended permit icmp any any
and also added the command.
icmp permit any int1
There is no ACL on my default gateway (Cisco 6500 IOS). And my interface has a security level of 90 without any managgement configuration.
If you've got any ideas of what I can check it we very sweet !
platinum_jem Wed, 09/30/2009 - 19:06
Can you show :
1) Interface config
2) Ping from your PC
3) "arp -a" from your PC. If ICMP is block , firewall will still respond to ARP.
kicharle Wed, 09/30/2009 - 20:15
Please make sure that you have following commands at the top. There should be no icmp deny echo/echo-reply above the permit statements.
icmp permit any echo-reply outside
icmp permit any echo outside
