7975 Screen background and Corporate Directory
Sep 30th, 2009
Greetings,
Is there a way to push a screen background to a select group of 7975's while have the remaining use the default? Or does this have to be manually selected on each phone?
And can the Corporate Directory be enabled on selected 7975's and not on others?
Overall Rating: 4.5 (2 ratings)
Abdulbaseer Mohammed Wed, 09/30/2009 - 20:48
I belive you can select the image for each phone in the device details.
You can select the prefrences where yoy can enable and disable the directory key for each user.
Hope it helps
Jaime Valencia Wed, 09/30/2009 - 21:04
The background image config is not in CUCM admin, it's on the phone itself
You can do it with the Cisco IP Phone designer or something like this:
Phone Remote.
http://www.voipintegration.com/software.html
As for the corporate directory since you don't mention what CUCM version you have i'll assume it's 7.X
You can create a blank IP phone service for the directory, or disable the enterprise subscription to the current one and only subscribe phones you want to have it.
java
if this helps, please rate
tsijmerrifield Thu, 10/01/2009 - 07:19
Great thanks - very helpful. I understand disabling enterprise subscription however can you please expand on the on the "blank IP phone service for the directory".
