Moving from CSM to ACE
Sep 30th, 2009
Hi all,
I have a CSM-config with 16(32 vlan) bridges in one context and want to move them to a ACE-blade. I can't declare more than eight route entrys. Shall I define defaultgateways as real servers and what about mac-sticky enable?
Mats
Gilles Dufour Fri, 10/02/2009 - 03:38
  • Cisco Employee,
you download reload need a gateway for each vlan. This was actually true for the CSM as well.
The csm has only 1 active default gateway.
It does accept more to be configured but only use one.
ACE only accept 8 but it uses all of them.
So, just define a few gateways - up to 8.
If the gateway is the MSFC, there is no need to configure hundreds time the same destination.
For mac-sticky, I would recommend to enable it.
Gilles.
mruuth Mon, 10/05/2009 - 04:57
Hi Gilles,
I'm sorry, but I don't understand your reply. Attached is my config for Vlan on CSM. There I declare a gateway for every client vlan. How should config look like in ACE regarding Gateway.
Mats
ppflaum12 Fri, 10/16/2009 - 11:09
you don't need the gateway ... just the mac-sticky enable
mruuth Thu, 10/22/2009 - 05:33
Hi all,
My rservers want to establish connections to other servers on other subnets owned by MSFC.
Mats
