CUE 3.1 upgrade and flash
Answered Question
Sep 30th, 2009
Hi all,
I need to upgrade a AIM-CUE 3.1, to hopefully 7.1.x. question:
1, according to Cisco docs, if the AIM-CUE has got 512MB compact flash, it needs to upgrade to 1G first. how do I check the how much is the flash now? I went through all the commands and even "show tech" on the module, can't find the flash size.
2, if I do a upgrade (not clean install), do I need to do anything about licenses??
thanks
Correct Answer by Hythim Ali El Hadad about 7 years 3 months ago
1. you can use show voicemail limits
if System Capacity (minutes): 480
then it is 512
480/60=8-hours storage
if 14-hour storage ,then it is 1GB
2. no
wish this be helpful
Overall Rating: 5 (1 ratings)
Correct Answer
Hythim Ali El Hadad Thu, 10/01/2009 - 08:17
then it is 512
2. no
Hythim Ali El Hadad Thu, 10/01/2009 - 12:48
hi,
this may clarify my post above:
CUE#show voicemail limits
Default Mailbox Size (seconds): 420
Default Caller Message Size (seconds): 60
Maximum Recording Size (seconds): 900
Default Message Age (days): 30
Default Prompt Language: en_US
Operator Telephone: 0
minghui.qi Thu, 10/01/2009 - 21:30
Thanks! I ran that commands, it shows the system capacity as 800 min, so I guess it's a 1GB flash one.
For the license, I found that since CUE 7.1, the licensing changes to the new scheme, you buy the mailbox license in increments of 5, etc. I thought since it's different from before, don't you need to get new license file or something like that??
Hythim Ali El Hadad Fri, 10/02/2009 - 06:53
yes
I have an upgrade like that lately
and i didn't deal with any upgrade license file
it is only if you'll change the no. of supported mail boxes
thanks
Adrian Saavedra Thu, 10/01/2009 - 10:02
I believe you can see compact flash information with show version from cue prompt.
Hope it helps, if it does please rate.
Best regards,
- Adrián.
minghui.qi Thu, 10/01/2009 - 21:34
thanks for your reply, I thought the show version command would show it, but it shows SDRAM not flash size.
