ASA 5510
Oct 1st, 2009
I have ASA 5510, i tried to login to it by telnet, but it seemed to refuse the user name and the password.
When i restart the ASA, it accept login with same user name and password, then after a while same problem occurs again.
So, if you please, what can i do
mkharban Fri, 10/02/2009 - 13:32
Can you attach the output of 'show resource usage' command at the time telnet stops working. Also, are you able to ssh to the box at the time this issue happens.
A 'show tech' output at the time of the issue will be highly appreciated.
Manish Kharbanda
