ASA5505 basic lic-DMZ to outside access
I have a new 5505 with basic license, and I setup DMZ as security 50, inside to out side no issues.
restricted access from DMZ to inside (that satisfy the license limitation), but I should be able to access internet(outside) from DMZ am I corrct.But I can't.
I dont have ACLs and I have
global (outside) 1 with interface
nat (DMZ) 1 with "DMZ subnet"
My understanding is of the asa and pix is, this should work.
Am I doing any thing wrong here, pls advise.
Overall Rating: 4 (2 ratings)
Collin Clark Thu, 10/01/2009 - 05:50
Only three active VLANs can be configured with the Base license, and up to 20 active VLANs with the Security Plus license. You can create a third VLAN with the Base license, but this VLAN only has communication either to the outside or to the inside but not in both directions. If you need to have the communication in both directions, then you need to upgrade the license. Also, if you use the Base license, allow this interface to be the third VLAN and limit it from initiating contact to one other VLAN with the hostname(config-if)# no forward interface vlan number command. Thus the third VLAN can be configured.
Hope it helps.
Thanks for th epost, this is the config
I am not sure it need a ACL to allow traffic out of DMZ to outside when u have "no forward interface vlan1" command, interesting though I can see the DNS resolution in the browser bottom bar when I try to go to a web site.
ASA Version 8.2(1)
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address 1xx.1xx.213.142
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
nat (dmz) 1
route outside 1xx.15xx.213.129 1
dynamic-access-policy-record DfltAccessPolicy
http server enable
http inside
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address inside
dhcpd address dmz
dhcpd dns interface dmz
dhcpd domain interface dmz
dhcpd enable dmz
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
Collin Clark Fri, 10/02/2009 - 05:28
You do need an ACL on the DMZ interface.
access-list dmz_access extended permit tcp any any eq 80
access-list dmz_access extended permit tcp any any eq 443
access-list dmz_access extended permit udp any any eq 53
access-group dmz_access in interface dmz
Try adding this, try surfing the internet, and check the logs.
jdlampard Thu, 10/08/2009 - 12:16
I believe you're missing a global statement for the DMZ.
What does the log show??
Hi, Thanks for reply, this customer installed a interim solution until they receive security plus license,
But, the single global statement is enough for both inside and dmz isn't it.
nat (inside) 1
nat (dmz) 1
When I get a chance to test this asa I will update the entry here.
