Unity Connection System Call Handler Take Message
Oct 1st, 2009
We use Unity Connection 2.1.4 integrated within CUCMBE.
Our Customer wants to disable the system call handler that comes after a personal greeting.
For Example: When you get to a Voicemail with personal greeting you will here: something like this: This is my Voicemail. you can leave me a message after the beep. Then you hear the Unity System Call Handler that you can leave a message as well. Is it possible to disable this?
thanks in advance,
Bernhard
Overall Rating: 5 (1 ratings)
ivarnhagen Tue, 01/26/2010 - 00:56
Hi, can anybody confirm that the call handler after the personal greeting can only be disabled in UnityConnection v7?? I have the same issue as Bernhard using Unity Connection 2.1.0.9901-362.
I would appreciate any feedback!
