Outlook Anywhere, Exchange 2007 and CSS 15500 SSL Off-load
Oct 1st, 2009
Does anyone have a working config for a CSS 15500 doing SSL off-load of Outlook Anywhere in Exchange 2007? This is different from Outlook Web Access. Outlook Anywhere allows you to use the full Outlook Client and tunnel RPC over HTTP. We have worked with Microsoft and currently working a case with Cisco and not having much luck making it work.
grubbdw@msha.com Wed, 12/02/2009 - 12:47
I guess I am going to have to bail on making this work.  I cant find anyone on the net that is doing this.  Micro$oft and Cisco support are no help.  I know I cant be the only one trying to do this.  This is the first time I have found a problem that Cisco does not already have a cookbook for or is able to provide and answer via support
