10-01-2009 07:07 AM - edited 03-06-2019 07:57 AM
I am working with the latest 12.4.24T1 code . Under the line definitions there is now a line 66 . Anyone have an idea what line 66 is ? The router just has 2 gig interfaces and a single wireless controller card installed. Had to migrate to this newer code for WLC . Was running 12.4.13b mainline code before and that wasn't there in that version.
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 0 CTY - - - - - 0 0 0/0 -
1 1 AUX 9600/9600 - - - - - 0 0 0/0 -
66 66 TTY 9600/9600 - - - - - 0 0 0/0 -
10-01-2009 07:55 AM
I've had 12.4(24)T on an 871 for a few weeks now and do not/have not had the extra line. Maybe it has something to do with the WLC.
10-01-2009 08:29 AM
Hmm could be but I don't think that's the case as its a TTY line . Almost looks like a modem line setup but there is no modem in this 2851 .It's on there as default when you boot this code up for some reason .
10-01-2009 02:00 PM
Sounds like the NME module Glen. Look at your config and do you see something like line vty 66 or something?
10-01-2009 03:16 PM
Yeah think you are right , pull the WLC out and it dissappears . Must the line for when you do the service session module command into the WLC , just starting to learn about the WLC's , that's a whole different ballgame than autonomous waps.
10-01-2009 03:44 PM
Thanks for the rating Glen. Let me know if you want help on the WLC. :)
