Redundant Bridges
Oct 1st, 2009
Hi everyone, i'm trying to do a redundant bridges, with 2 root bridges and 4 non-root bridges. So normaly 2 non-root will connect to a single root, but if one root is down, his two non-root will connect to the other root, and this works fine with the parent command in the non-roots, now this is the question: Is it posible that when the root that was down then goes up his two non-roots get back to him? a kind of fallback? If someone can give an advice or a link of configuration i'll appreciate so much. Thanks in advance.
Milton Tizoc Thu, 10/01/2009 - 09:19
Well, the customer doesn't have a WLC, a for the moment we are trying in autonomous mode.
thanks.
Milton Tizoc Fri, 10/02/2009 - 06:38
Thanks for the link, but in that one doesn't say about the fallback.
Thanks any way.
ericgarnel Fri, 10/02/2009 - 06:55
I'm not sure if there is a non-mesh Cisco solution that will do that. The network infrastructure could offer the resiliency that you are looking for via the redundant bridges either through ip-sla or spanning-tree tweaks
Milton Tizoc Tue, 10/06/2009 - 17:09
Hi eric,
i'm thinking too that also that is no posible with out mesh, i have not seeing any about the solution i'm looking for, any way, thank you so much for your time and advices.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
